VIN Help
Old Feb 23, 2020 | 03:27 PM
Josh Beverly's Avatar
Default VIN Help
Bought a junkyard engine and need to back out the VIN so I can buy the right rebuild parts. I bought a set of Dura-Bond CH-25 cam bearings and journal number 4 was too tight.
The casting number on the back is 12567392. The number on the driver's side deck is C51364287.
Old Feb 23, 2020 | 04:34 PM
B52bombardier1's Avatar
Did you get the PCM with this engine from the donor vehicle? The VIN is embedded in the PCM operating system tune file and can be read by people skilled with HP Tuners, or a combination of LS Droid and Tuner Pro RT software.
Rick
Old Feb 23, 2020 | 04:59 PM
No. The engine was a core from a rebuild that the VIN is unknown. The harness, PCM, etc. came out of a junkyard Suburban and I know that VIN.
Old Feb 24, 2020 | 08:48 AM
1964SS's Avatar
LS Family: Gen. 3, 4.8L / 5.3L, Iron Block, Truck Engines Engine Block Specifications Casting Numbers 12567392, 12567393, 12551358
Casting Number 12567392 Manufacturer Chevrolet Category Engine Blocks Type LS Small Block V8 Date 1999-2007 Notes Vortec 5300, VIN "T", 5.3L / 325 CID,
NOTE: Cam bores changed some time in 2003
Old Feb 24, 2020 | 10:05 AM
I know it is the 5.3L. It has drive by wire. What I don't know is the exact year and that's why I want the VIN. I updated my original post with more laser etched numbers. Need to know whether I need the CH-10, CH-23, or CH-25 cam bearings. The last set I tried were the CH-25.
Old Feb 24, 2020 | 01:42 PM
1964SS's Avatar
I believe there are only two designs. 2003 and up are the second design. CH-23. First design is CH-10
2nd design. Positions 1 and 5 housing bores are 2.348 in. and 2.348 in.
Old Feb 24, 2020 | 03:13 PM
I would still like to know the VIN if someone can talk me through it.
I'm familiar with the differences. But my rotating assembly is in place and it's difficult to measure the bores. Bores 1 and 5 are also in between the two values. With my calibrate calipers it is just less than 2.340".
Old Mar 1, 2020 | 04:11 PM
Struck out with my local dealership parts guy as well as GM parts direct. It would be nice if there was a formula for the derivative VIN on later models.
Someone has to know what is laser etched on the heads and block.
Old Mar 1, 2020 | 07:42 PM
chevymec's Avatar
If the C51364287 is the end of the vin, the dealer can get the entire vin from the last 8 digits. Not sure why they couldn't if it is.
Old Mar 1, 2020 | 07:49 PM
A normal VIN only has six numbers in a row as far as I know. For example, the 05 suburban I pulled the harness/PCM from was 3GNFK16Z95G138128.
