Corvette Regulator Filter
Old Mar 8, 2020 | 11:36 AM
chrisluke50's Avatar
Default Corvette Regulator Filter
I was wondering if the return port on the vette filter is supposed to be hard to blow air through? I couldn't get air through by blowing through the port or sucking. the other ports on the filter were fine. I am working on a swap project and am having lean issues.
Old Mar 8, 2020 | 12:36 PM
CutLS's Avatar
My guess is that it should be harder because it is regulated pressure and should open when it gets to certain pressure.
Old Mar 9, 2020 | 04:41 PM
1964SS's Avatar
Who makes the filter regulator you are using? There are several junk units being sold out there. I will only use the WIX or NAPA regulators now. Have you verified your fuel pressure at the rail to see if it's correct?
Old Mar 10, 2020 | 11:58 AM
67_ls1's Avatar
^^^^ What he said.
