Looking for "biscuit"style motor mount options for ls swap into Merkur XR4Ti
Looking for any and all options for mounting an LS in an XR4Ti, the use SIMILAR mounts to a fox body but not the same. I have come up with a few workable options but figured I would tap all your collective knowledge prior to pulling the trigger. I am sure mounts have been covered a million time, it seems most swap are mounting of the frame or x member. which is not ideal for my set up.
The following users liked this post:
LS BRAVADA (04-21-2020)
Joshua Grisolia (04-20-2020)
Lots of different shapes out there.
Look halfway down this page at the Mopar mounts used in this C4 swap (they are nice if you need an offset on the studs)
https://tech.corvettecentral.com/201...-c4-corvettes/
C5 corvette mounts are like tall rubber biscuits.
Many variations of these basic style
https://www.speedwaymotors.com/Unive...-Kit,1199.html
https://www.dirtydingo.com/shop/prod...oducts_id=1317
These with the c5..I have a narrow tunnel car if yours is 87+ you may not need it. and you can use the trans-dapt one which are not adjustable
Thanks for the information, also which oil pan were you using? I Am currently using an F body pan from an 1998 Camaro, and I don't have the room needed.
I am using a Canton racing road race pan but, you can use gm GM muscle car swap pan or a Holley retrofit pan. They both clear and pretty much any steel fabricated pan like jegs or summit brand
The GM C5 mounts work great, they are oil filled and really isolate the chassis from vibration. My old car has them and I had to design them into my front crossmember but it was worth it.
Manualswappin (07-30-2020)
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/1024x768/ford_sierra_rear_7e6382730d6fbd659624371fd0645ec39b7215ab.jpg)
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/1024x768/ford_sierra_rear_axle_to_engine_mount_b78df837d0474094a8c224cd026e5663f0b41ba0.jpg)
This is a very cheap one, only few dollars. Took the control Arm Bushings from this axle (Ford Sierra) on back yeard. Welded Bushings to an original front axle on my Ford Sierra 1989. It held LSx in its place under many years. Sorry for my English.
