Fuel pump issues
Old Mar 10, 2020 | 09:43 PM
brianthompsonsmith's Avatar
Default Fuel pump issues
I swapped a 4.8 4l60e into an 87 square body 4x4 put a cheap quantum 255 pump in the tank it lasted a little over a month no problems and then had hard start and sometimes no start problems replaced with walboro 255 pump that only lasted 6 days and left me set I took pump out of 2000 chevy truck I pulled motor and tranny out of for swap and put that on my sending unit and seems to be fine so far I had a 14 guage wire run from relay to pump on first to since then I put 12 guage wire in from relay to pump any thoughts on problem would be greatly appreciated.
Old Mar 11, 2020 | 04:07 AM
showdog75's Avatar
Make sure you're grounds are clean and have good contact.
Old Mar 11, 2020 | 05:10 AM
B52bombardier1's Avatar
How much gas do you keep in the tank? These pump motors use the fuel as a coolant and with small amounts of fuel in the tank they get hot and sometimes seize up.
Rick
Old Mar 11, 2020 | 05:38 AM
reedld's Avatar
Rick
heat AND sucking air shorten life. Sounds like you put in an entire 2000 fuel bucket in your 87 tank? That should work...GM designed that bucket for 5.3/4.8 engines. You wind need a baffle either. I run have run my tank down to 1/8 (LS1 fuel bucket) with no issues.
Old Mar 11, 2020 | 07:12 AM
The truck was 3/4 full both times it happened just seems odd that it went threw 2 pumps .
Old Mar 11, 2020 | 01:01 PM
blackhawkMC's Avatar
Are you running the stock engine-mounted vacuum regulator? Do you have a return line for the fuel?
Old Mar 11, 2020 | 02:30 PM
Yes I am running stick regulator and a return line.
