Ls swap gurus please
Old Mar 16, 2020 | 12:26 PM
hpjunke's Avatar
Default Ls swap gurus please
Ok after reading all this great info i had a question regarding my pedal combo in my dads 73 Camaro Ls swap project . I have an 05 truck pedal and module but i want to use the 97-04 Corvette pedal . Looking at the diagram pin out it appears to share the same as the truck plug style and all but i’ve also read where it has to have the Corvette tac moudle for this to work . I also have the 8 pin throttle body also that is truck related .Any info on this would be great !
Thank you in advance
Sonny
Old Mar 16, 2020 | 02:41 PM
LetsTurboSomething's Avatar
This is copied from another thread from Bo185
"Truck DBW components
The TAC module has two connections, one for the pedal harness..other hooks into main engine harness there are two styles the 9-pin connector the later ones are 6-pin.
TAC modules have to match up to the year range of the PCM AND the throttle body.
03-06 TAC module works with 03-06 truck TB and 03-06 PCM (BLUE/GREEN connectors)
01-02 TAC module works with 01-02 truck TB, 97-04 Vette TB, and 01-02 PCM (BLUE/RED connectors).
03-06 TAC modules have an aluminum mounting base, 01-02 TAC modules are all black plastic including the mounting base.
The newer 07 up take a different pedal assembly."
