DOD delete oil passages plugged or open?
Old Apr 20, 2020 | 09:49 AM
AS688's Avatar
Default DOD delete oil passages plugged or open?
Should I plug the the oil passages in the valley of carbed DOD delete block? If so what are you using for the plugs?
Old Apr 20, 2020 | 10:51 AM
TrendSetter's Avatar
you can buy a new valley plate that blocks them off. i dont have the part number right now but i just installed one.
Old Apr 20, 2020 | 02:26 PM
AS688's Avatar
Yes, I have a new cover on the way but wondering if I should do more. Saw on another site that it may help oil pressure.
Old Apr 20, 2020 | 02:43 PM
Some guys tap the tops of the towers and put Allen head screws in them. The O-rings can seep oil, but it's not a major issue.
Old Apr 20, 2020 | 03:58 PM
Project GatTagO's Avatar
The LH8 2009 Colorado 5.3L (and probably other engines) is a gen 4 block but did not have DOD, so the cover has the o-rings on the bottom to seal off the passages. Tapping and plugging those holes kist seems like extra, and unnecessary work.
Andrew
Old Apr 21, 2020 | 07:52 AM
Andrew
yes, i dont understand why you would spend all that time and effort with plugs and screws when you can just install a cover thats designed to block off the ports.
Old Apr 21, 2020 | 07:54 AM
here you go, 10 seconds of googling
https://ls1tech.com/forums/forced-in...l#post19740221
Old Apr 21, 2024 | 12:36 PM
chevydarrell's Avatar
Default O rings
O rings are famous for there failures!! Remember the Space Shuttle booster?
Old Apr 23, 2024 | 02:55 PM
rodstored-72's Avatar
having dealt with this exact issue & therefore having to rebuild the engine twice. I would HIGHLY recommend plugging the towers. BTR (other sites too) sells a kit for this exact reason.
Old Apr 23, 2024 | 02:57 PM
did you bump your head?
