GM Type 2 pump- Tbird rack?
Old Jun 12, 2020 | 02:10 AM
jarrett wininger's Avatar
Default GM Type 2 pump- Tbird rack?
Hi I have a 64 nova that ive done an ls1 swap into and am trying to sort out the power steering connection. This is my first build so forgive me for ignorance. Have been searching the last couple days and even tried to install the speedway kit which goes to saginaw type 1 PS pump. I have the Holley mid mount race accesory kit so its a GM type 2 but im sort of getting lost in how to connect it to my T Bird PS rack on my heidts mustang 2 front end. What route do i need to go? PSI reducer? Thanks
Old Jun 12, 2020 | 05:35 AM
Michael Yount's Avatar
https://www.turnone-steering.com/blo...him-kit-theory
Don't worry about reducing PSI --- set it up and drive it. If it feels twitchy/over-boosted, use one of these ( https://www.jegs.com/i/JEGS/555/60791/10002/-1 ) to reduce the flow. I run a GM type 2 on my LS3 and it powers the Volvo ZF rack just fine from a pressure perspective. I used one of the flow control valves to reduce flow and the steering in the car has never felt better - great feel, not over-boosted.
Old Jun 12, 2020 | 09:36 AM
79LS1FOX's Avatar
I use a turn one flow reducer on my setup CTS-V pump to FOX Mustang rack. Works perfect.
Old Jun 12, 2020 | 11:39 AM
You nailed it. I'm no hydraulic expert, but when mixing/matching hydraulic components, it's usually a matter of matching volume, not pressure to get things functioning. Pressure only comes into play when maximum pressures are hit.
Old Jun 12, 2020 | 01:24 PM
33willys's Avatar
Heidts has their act together regarding the MII and use the T'Bird rack because it does not need pressure reducing. The T'Bird has two racks, sport and regular. The one to use (and I'm sure they provided it) is the non-sport which requires more turns lock to lock. Much cheaper than a Mustang rack too. I'm using the T'Bird rack on my '39 and it works just fine.
Old Jun 12, 2020 | 02:22 PM
33 - is the quicker rack actually quicker because of different rack/pinion ratio - or less turns lock to lock because they move the stops? Some of the Stang racks that are less turn lock to lock are less turns simply because they don’t turn as far.
Old Jun 12, 2020 | 04:57 PM
33willys's Avatar
I think the ratios are different because I got both and the wheels turned the same arc. Also did some research and the non-sport was recommended and a better match with the GM pump pressure.
A while back I got to thinking about the mis-matched pressures for GM pump to MII rack and wondered why not just use a Ford pump?
Old Jun 12, 2020 | 06:28 PM
ls1nova71's Avatar
When I first built my '33 I used a turbo coupe rack and it was way too fast to drive comfortably. I switched to a regular fox body rack and it's much better now. The t bird rack was fewer turns lock to lock, but still turned the same amount as the mustang one.
Old Jun 20, 2020 | 11:12 PM
I think where im getting confused is what type of lines and hardware do i need to connect the two. Im using the 84-88 T bird rack a buddy gave me, and the speedway GM type 1 pump kit didnt work. It looks like the gottashow setup might since it seems to support the male AN from the type 2 pump and has the connectors for what i beleive is 14mm and 16mm pressure and return on the rack. Or am I supposed to just build the hoses and crimp it on my own?
Old Jun 21, 2020 | 07:03 AM
I had the local folks at Pirtek build the high pressure side for me --- GM CTSV pump; Volvo/ZF rack. The low pressure side is pretty easy assuming you can find the correct barbed fitting....just used 3/8" parts store low pressure PS return hose and clamps.
Old Jun 21, 2020 | 04:30 PM
ls1nova71's Avatar
I used the Gottashow hoses, but had to fab a fitting to go on the high side of the pump because of the way the pump is mounted on a 2001 F body LS1. I like that the rack ends swivel like a factory Ford line. They have worked well over the 12 years I've been driving my car.
Old Jun 24, 2021 | 01:41 AM
Ok sorry to dig up bones but this build has been more than a headache. Probably bit off more than I should chew but I'm moving forward.
Built lines myself and after many blisters got them to seat on the plastic return side of the pump reservoir. After a couple of start ups I noticed the hose leaking, and the base connection where the lines meet the rack. Gonna rebuild the lines with steel braided but is there any tricks I should use for sealing that connection at the pump? Pics?
Also, it seems only the bottom line leaks at the rack, and I didn't use thread tape on recommendation from a friend... Should I just thread tape and see what happens or is it possible I just over tightened and blew the threads?? Upon inspection it seems the threads are intact. Really hard to get a torque wrench in there so just going off snug feel.
Old Jun 24, 2021 | 08:14 AM
1964SS's Avatar
Are you using the T-bird style rack too? The t-bird rack is O-ring style not inverted flare. Definitely no thread tape needed on those fittings. I used a premade kit I found on speedway motors recently.
Old Jun 24, 2021 | 11:32 AM
Yes using T bird rack and just noticed those O rings. So maybe my threads are trashed.. I tried the speedway setup but it was too cramped, the heidts front end is a bit narrow and was interfering with the fittings. Actually tried two different prebuilt setups from them and they wouldn't take the returns.
Old Jun 24, 2021 | 01:23 PM
1964SS's Avatar
Yeah I had an issue with them being 90 degrees at the pump which did nothing for me. I put them in a vice and bent them to about 45 degrees and they work good. lol
Your best bet is to probably buy the 3 o-ring to 6an adapters and make yourself a couple an hoses.
Old Jun 24, 2021 | 03:35 PM
LS1 TJ's Avatar
Make sure you use the teflon lined -6 SS line on the pressure side. On the return size you use just regular power steering rubber line. Just need barbed -6 fitting.
Old Jun 24, 2021 | 05:40 PM
I had made the lines out of an early high pressure line and it seemed like the pressure side was fine, but the return line was wet and the point at which it connects to the p/s reservoir is not a traditional threaded point. It's like a nippled plastic end so I used a clamp style fitting but it seems like it didn't secure well enough.
Old Jun 25, 2021 | 10:00 AM
showdog75's Avatar
Use some silicone lubricant for the hose end. Makes a huge difference on stubborn hoses. Speedway sells a -6an fittings for the rack if you don't already have them. I just replaced a wore out rack on my Heidts clip Chevy II wagon.
