Lexus LS400 build
Not much of an update got a set of my favorite wheels that I've been on the hunt for. Then the beginning of August the corona got me but I'm starting to feel like myself so its time to get back on this project stay tuned. 👍
Glad to hear you're feeling better. Nice work on the car. Dig the wheels.
Jay
And it begins
AFL filter was pretty nasty and had a hole in it.
Wasn't really that bad this was half way through it. Everything has been removed and took it with me to work so it can soak in the parts cleaning tank.
They also have a brace in the middle i forgot to snap a photo of it.
Either going to run a spacer or trim that outter edge, depends if the mount is molded to it. What do ya'll think I should do?
Sits on the rack but spacers should help with that
Enlarged drain back
Tiny little hole
This thing got alittle hawt lol
Before
Before
After is this little notch ok?
After
Washer stacking, plan on getting some steel tube cut to the same size as the washers for a cleaner looking spacer.
After posting this i realized there was an extra washer on the driver side.
Good tunnel clearance.
Alot better pan clearance might remove one from each side (2 from the drivers side since I had an extra) to get more bite on the mounting post nuts.
Hoepfully ill get some time to work up a transmission bracket this weekend.
Ck performance master kit
Toasty roasty lol
Clutch disk
Toasted clutch disk
Loaded with clutch material...
This doesn't seem normal to me
This shows a good bit of wear also so I'll probably write this one off and source another good direct clutch assembly.
The center support was pretty much straightforward to do
Upgraded these with the ck performance master kit
Beefy springs and retainer plate
New teflon seals had to order another set for the other side they didn't want to go on as easy as these did. Stay tuned for more just waiting on parts to come in.
So canton wants like $20+ for a pan plug. Luckily i have a well stocked advance auto 5mins down the road so i picked up this plug for $3 and a trans mount for $25.
Pan plug installed
Also looks like the oem lexus transmission bracket is going to come in handy.
Tail shaft hangs roughly 2.5 inches past the mount which isnt to bad
New energy suspension mount installed.
Just have to fab up a plate to connect everything.
