Lexus LS400 build
Got the car on the ground to see how far the sway bar rolls back.
Not to bad time to install the balancer.
Old balancer on and have little ove a 1/2" of clearance
Don't think the ls1 lower alternator bracket is going to work have to search for some tight clearance brackets. Y'all have any ideas on what i can use with truck spacing?
Showing how wide the bay is.
TBSS intake sits high but i got it with rails for $190..
Looks like i might be the only ls400 thats going to rock a hood scoop lol. Hopefully this weekend i can get back to work on the transmission.. was holding off as long as i can. The empty trans case makes pulling/installing the engine so mich easier.
Attachment 713137
Luckly this small case alternator works. It's snug but thats also with the ls1 bracket. My ICT truck spacing brackets shoild be here soon along with more accessory drive items.
Jist glad I don't have to go this route... this was going to be a last resort Idea lol.
Still working on the transmission had order another center support bushing got the new one pressed in but needed to seat it down alitte further and this happened.
Waterpump came in, looks good with the ICT billet brackets.
Test fitting the radiator, might see if there is a slimmer option. The mk3 toyota supra radiator is replacement option for this car but this one is a 3 row and is super thick. Might limit my options on the turbo crossover options.
Looks like the hooker turbo blackheart manifolds might be my only option.
Also got the new center section bearing pressed in and managed not to fudge it up this go around lol
