Lexus LS400 build
For a car that came with an OHC V engine it certainly lacks room in the engine bay.
About 85% finished with the transmission. Main parts are input shaft/overdrive section, pump and then valve body. Enjoy the small pic dump I'll have more when I make more progress. Also got the summit sfi flexplate on.
Electrical tape is to keep the orings from expanding
and start messing with the manifolds and turbo placement.
Also I realized I took this after swapping the rear lube tube hold down so rest assure its in the right spot lol.
Now on to the manifolds, I had 2.5" v bands welded on them.
The plan is to go 2.5" to 2.25" then a 3" down pipe. All the exhaust piping is on order from summit (super fast shipping). Here goes the manifolds test fitted.
Only issue is the driver side manifold rubbing the back of the ict billet alternator bracket. I'll probably do some slight trimming of it because I would like to run this mount for better stability. I see lots of heat wrap and tape in this build haha.
On the driver side I'll have to do a U bend or a 45 straight off the v band.
Beefy 1 1/4" tubes
Mounting tabs I'm going to use
Plenty of room for fans, plan on using a 00 camaro oe fan setup
And the trash hauling truck after a few upgrades to make more comfortable to drive daily good ole 2.3 lima.
