Knock sensor question
Old Jul 12, 2020 | 09:41 AM
showdog75's Avatar
Default Knock sensor question
Will a exhaust pipe rubbing cause the knock sensors to pull timing and retard the engine? I'm shaking out my swap and I suspect this could be a cause of the engine stumbling upon acceleration. Pipe is hitting the trans cross member as I tucked everything in as tight as I could and have a small area that's definitely rubbing/hitting with engine/trans movement.
Old Jul 12, 2020 | 10:40 AM
Michael Yount's Avatar
While I don't know if the vibration could cause a knock sensor reaction (doubt it - they're looking for VERY specific 'noise' in a certain frequency) -- I don't think the knock sensor signal would result in pulling so much timing or changing fuel mixture so much that the engine would actually stumble. Have you pulled codes?
Old Jul 12, 2020 | 10:47 AM
Twin_Turbo's Avatar
In any case remove it as a variable.
Old Jul 12, 2020 | 10:48 AM
showdog75's Avatar
Not throwing any codes
Old Jul 12, 2020 | 11:39 AM
Rubbing and hitting are two different things. Hitting COULD affect a knock sensor, depending on the sharpness/severity of the hit. Rubbing, not so much.
Old Jul 12, 2020 | 11:56 AM
showdog75's Avatar
I'll call it a hit.
Old Jul 12, 2020 | 07:38 PM
showdog75's Avatar
Regardless the car is back on the lift stands and the exhaust is getting some more love.
