Ls3 swap, limp mode! Help!
Old Aug 30, 2020 | 11:42 PM
Jet242009's Avatar
Default Ls3 swap, limp mode! Help!
Hey all, my ls3 swapped 2000 ws6 is throwing one code P1276, and upon startup I have no pedal (drive by wire) after deleting the code with a scanner the pedal comes back, but the car has a major cut in power. Im not very familiar with these swaps so Im just trying to learn what I can and hopefully fix it. Im thinking its possibly the tps, but Im honestly guessing.
thanks for your help!
Old Aug 31, 2020 | 07:00 PM
B52bombardier1's Avatar
Did this throttle pedal and TAC module come with this engine from the donor vehicle?
Rick
Old Aug 31, 2020 | 07:07 PM
Jet242009's Avatar
No, ls3 is out of a 2015 camaro, tac/throttle pedal are out of a pontiac G8. I also noted two more codes on startup today, P1516 and P2101. Ive checked all of my wiring and found no issues with loose connections/plugs and none of the wires have any bare spots,kinks, or breaks.
Old Aug 31, 2020 | 07:21 PM
I'm no expert but there are incompatibilities between pedals, TAC modules, wiring harnesses, PCM's and operating systems within PCM's. I hate to make predictions, especially about the future (I'm borrowing this quote from a famous dead guy) but I'd bet you have a problem here with compatibilities.
Rick
Old Aug 31, 2020 | 07:26 PM
Jet242009's Avatar
Im really hoping not, car was tuned/dyno'd with these parts by the previous owner. It just recently started having problems...sooooo im hopeful...going to be taking to a speed shop this weekend and with any luck they can help narrow it down. Honestly though, i feel like it would be less of a pain to just convert it back to drive by cable. Are there any real bonuses to keeping it drive by wire?
Old Sep 7, 2020 | 05:04 PM
Gen IV ECM's will not support DBC.
Old Oct 2, 2020 | 04:34 AM
Jet242009's Avatar
are you sure? Theres a ton of people claiming to have done it and adapters for sale....regardless, figured out what was going on! Torque management was tuned out and speedo was wayyyyy off!
Old Oct 2, 2020 | 10:43 AM
Not a single Gen IV engine/ECM came DBC capable. You might be confusing this with many Gen III DBW ECM's that had DBC capability.
