vehicle speed sensor
Old Nov 1, 2020 | 06:55 PM
Seeker1056's Avatar
Default vehicle speed sensor
Ok - so after lots of reading - I can not find anywhere where a stand alone engine wiring swap requires a vehicle speed sensor - however my new aftermarket engine harness designed for stick or pre electronic trans ie T350 - T400, says to have a VSS installed to prevent stalling on hard braking etc??
if in fact I need a VSS - how where etc and with what, do I install one?
thanks in advance
Old Nov 1, 2020 | 09:17 PM
Project GatTagO's Avatar
thanks in advance
It is not required, but highly desirable.
Andrew
Old Nov 1, 2020 | 09:59 PM
Seeker1056's Avatar
if desirable - how does one go about intalling one somewhere on a vehicle with zero electronics?
Old Nov 1, 2020 | 10:16 PM
Seeker1056's Avatar
https://www.ebay.ca/itm/202805712412
problem solved
Old Nov 2, 2020 | 06:15 AM
Michael Yount's Avatar
You can also use an old-school pickup/magnets on the driveshaft such as used by many aftermarket cruise-control units.
Old Nov 2, 2020 | 06:47 PM
That's a Hall Effect sensor (3 wires) the stock GM VSS are VR (2 wire).
Andrew
Old Nov 2, 2020 | 08:32 PM
lumen8's Avatar
thanks in advance
This works.
https://www.dakotadigital.com/index....rod/prd916.htm
It is 3 wire also (red, black and white) vs the GM 2 wire, but that is because it wants 12V to operate, on top of the 2 signal wires.
So give it ignition 12V on the red wire , black wire goes to PCM's VSS 'low' , the white wire to the PCM's VSS 'hi' , i'll put up the following example, an 0411 PCM , look at the bottom diagram for the low and high pinouts. If you have a newer PCM find the correct hi and low pin outs for your PCM.
Attachment 713543
Old Nov 3, 2020 | 02:48 AM
garys 68's Avatar
Dakota Digital sells a pass thru 2 wire pass thru sine wave VSS that allows you to use your mechanical speedo too. It works, not sure if a 3 wire square wave will work. DD also has a short speedo cable extension if the VSS is tight against your floor pan. It does not put out a high enough ppm to get the 411s DBW cruise control to work well. I've also used aftermarket 2 wire VSS on a T10 manual trans revere gear as a reluctor. You just need the spacing between the VSS and reluctor to put out enough voltage for the 411.
Old Nov 3, 2020 | 06:30 AM
TrendSetter's Avatar
depends on your ecm. gm stuff uses VR 2 wire sensors. if you have a terminator x you need a 3 wire hall effect.
i just installed the wheel from jags that run. $90 and went right on the rear yoke.
