need help with putting the ls1 in a 93 chevy truck
i have a 92 tbi with the 700r4. what do i need to keep my stock transmission and install the ls1?? i know i need motor mounts and a wire harness, but what about the radiator and all my existing accesories. i.e ac compressor?? do i need to buy new parts or re-route stuff?
Basically you will need to get all of the acces, off the new block because all the old accesories can't be used except the radiator and if you have a oil cooler, etc, for the fuel system you will need to upgrade the pump so that it will be able to pump 60 psi, new motor mounts, and a specialty bellhousing or flywheel because LS1 tranmsisions WILL NOT bolt up to gen 1& 2 motors.
