DBW throttle body issue
first thank you for your help.
I have a 87 C10\R10 with a 2006 Tahoe 5.3 with harness/ecm/tac/DBW.
I have disabled VATS, made it speed density. Currently the o2 sensors and the IAT sensor aren’t plugged in.
the throttle body is working with key on, engine off, it opens from 20% to 99.xx%. However When the engine is turned on the throttle body works for maybe 5 seconds then it stops responding, the engine idles rough then it dies.
does anybody know why the throttle body just stops working? I don’t have any codes for the throttle body and it seems to be communicating with the TAC module fine until the engine is turned on.
It sees to be a common problem with the throttle body, and a shut down and restart usually cures the problem.I am going to replace the TB and hope that fixes the issue
I should add that this problem has cropped up in the last 10,000 miles or so ( of 30,000) and has been quite intermittent but is getting worse.
