Bosch 044 Check Valve; Keep or remove?
As an aside, I suspect my first Walbro was a counterfeit, as it lasted 30 minutes (Ebay seller). The next one (Summit purchased) lasted around 500 Sunday afternoon miles. I'm running an Earl's 85 micron pre-filter, and a Vette filter/regulator on an LS1. I would have thought it should have lasted a lot longer.
Andy1
And the pump will flow a little more without the check valve, if you actually need that.
So exactly how are they installed, where, exactly what pre-filter, line sizes, lengths, etc etc ?
Yeah, I'm surprised/concerned of the short lives. I will dis-assemble the pre-filter to see if it's clogged. I'll check the fuel tank as well.
The first Walbro simply quit. The second one started whining, then quit.
Andy1
Andy1
Mine is a fairly new install also, so really not too sure about longevity also.
Dirty pre-filters prior to a pump will kill them everytime.
Andy1
-6 supply line to an 044 is too small. And it should be short hose runs.
There is no issue at all with a pre-filter as long as it is a proper one and not a small piece of **** as quite often people choose to run.
Inline pumps like this must always have a good, clean uninterrupted gravity ( or pumped ) supply of fuel.
Failure to have this will kill pumps.
044s do have a mesh screen inside, but it's still good practice to have a good pre-filter
Andy1
How is the pump wired? Large enough gauge wiring?
Put a proper filter on it, and up that supply line to at least 1/2" with suitable fittings. And often the M18 fittings at the pump can have tiny holes in them for some reason, if need be drill it out as big as is practical.
The 044 and pumps like it were common on millions of vehicles in Europe, single pump, inline, always gravity fed ( except some Volvo lol ), local and underneath the tank with a mesh strainer inside the tank pickup.
Given there is a mesh trainer inside an 044, and if you were pretty sure your tank and fuel supplies were always clean, you could forego a separate filter before the pump.
But in general I would not. IMO, use the biggest 40-100 micron filter you can so there will be zero restriction at all to flow. I've used the these before, https://www.holley.com/products/fuel...arts/230630ERL
Or the equivalent Aeromotive. I've also used 40 micron in the same style without issue.
Are they oversized for the task in hand ? probably....which is exactly the reason I used them. ZERO restriction.
I can only imagine the pump on Andy's car was screaming it's head off trying to get fuel through those small lines and very restrictive filter.
ALL 044's have M18x1.5mm inlet threads
but yes if it is a multipump setup, some pumps may require a check valve.
I don't have the cars any more so I can't take a pic but I could of sworn it was part of the 044 pump not an adapter on the input side. No doubt I could be wrong.
https://www.ebay.com/itm/SYTEC-MOTOR...-/264414055903
