e38 windstar wiring help please
Old Feb 9, 2021 | 07:58 PM
Nawcor's Avatar
Default e38 windstar wiring help please
So I thought I had this figured out, but now I've second guessed myself and at this point I'm burnt out. This is sorta what I was following but will this work on Windstar fans? Or is this trying to kick both fans on high when only 1 on the windstar actually goes into high? I'm just confused at this point lol.. Any help would be appreciated
Old Feb 9, 2021 | 11:50 PM
Is this a series/parallel circuit? If so, by running the fans parallel at first they run slower. Then when more air is needed they run in series, speeding them up.
If need be, google "series/parallel engine fan circuit" to see how it should look.
Also, look up ls1fans.com for ready made harnesses to do exactly what you want to do.
Old Feb 10, 2021 | 07:52 AM
79LS1FOX's Avatar
I think its opposite, series is low speed parallel is high speed, but that circuit looks good to me.
Old Feb 10, 2021 | 10:19 AM
You are right! Must have been too late for straight thinking.... LOL
Old Feb 10, 2021 | 12:47 PM
Nawcor's Avatar
Well, I'm going to take your word for it lol. I thought this was correct but I think when i saw the two "high speed" on the picture I started debating myself.
Old Feb 10, 2021 | 01:14 PM
TrendSetter's Avatar
i just did this on windstar fans and it works great. i used a factory fan harness from a 2006+ silverado coupled with an 0411 pcm.
Old Feb 10, 2021 | 01:19 PM
Nawcor's Avatar
Awesome, well I will continue on then. Thanks for the input
