Brake Master Cylinder bore size - 67 camaro
Old Mar 1, 2021 | 09:34 AM
youngrigo's Avatar
Default Brake Master Cylinder bore size - 67 camaro
I was planning on using the brake master and booster from my 2001 Camaro on my 67 Camaro build but the fittings on the brake master are on the wrong side.
So now i planning on using the brake booster but want to replace the master. I'm looking at a master with a 1in bore. Does anyone know if that will work or would i need a 1 1/8in bore?
Old Mar 3, 2021 | 10:17 AM
Project GatTagO's Avatar
A 1" bore MC would work well. See post #72:
https://ls1tech.com/forums/conversio...n-3-0-a-2.html
Andrew
Old Mar 3, 2021 | 02:03 PM
Jimbo1367's Avatar
Rock auto has all Kinds of info like that listed in their website. Rad. Hose dia., / p/s hose pitch and I.d or o.d all of that sort of thing you might want to know when swapping various parts from vehicles.
Old Mar 3, 2021 | 07:44 PM
33willys's Avatar
When mating a new M/C to a booster be very careful about the pin between them. The adjustment of that pin is critical.
Old Mar 4, 2021 | 09:46 AM
youngrigo's Avatar
Andrew
Do you by any chance happen to have the part number for the Raybestos MC?
Old Mar 4, 2021 | 02:12 PM
youngrigo's Avatar
For anyone interested the Raybestos part number is MC390572 for the 1" bore S10 MC with the fittings on the drivers side
