02 LQ9 Engine Drive By Wire To Cable
Old May 29, 2021 | 06:41 PM
War165's Avatar
Default 02 LQ9 Engine Drive By Wire To Cable
Hello!
Not sure if i'm posting in the correct area so i apologize if not.
I'm in the midst of swapping my 97 mustang GT to an LS setup.
My only concern is that the engine i plan on purchasing is drive by wire and my pedal in the mustang is drive by cable.. Would i just need to purchase a cable throttle body along w the drive by cable harness? or is it not that easy?
The engine will be paired w a T56
Also off topic - For an LQ9 engine is 150k miles too much to perform a cam swap w valve springs?
Thank you!!
Old May 29, 2021 | 07:00 PM
You will need the pedal assembly from the car the engine came in, or one like it.
Old May 29, 2021 | 07:25 PM
War165's Avatar
So it would probably be best to just buy a drive by wire pedal and mount it along w the PSI wiring harness for it?
Old May 29, 2021 | 07:34 PM
68Formula's Avatar
You would need to make sure your PCM has the driver for the IAC.
