Wire brake switch for 4l60e
Old May 30, 2021 | 09:50 AM
97camer's Avatar
Default Wire brake switch for 4l60e
Have a 99 camaro 4l60e, need to wire into brake switch on a 97 camaro that has a 6 pin - a 2 pin and a 4pin connectors, just need to know what two pins on the 4 pin will make a constant circut for my pink and purple tranny wires , i believe that is how its supposed to work. Hope this makes sense.
Old May 30, 2021 | 09:39 PM
Haggar's Avatar
What ECU are you using? If you are using a factory ECU, you need the terminals that are 0 ohms across them when brakes are not pressed, and open circuit when the brake is pressed.
Old May 31, 2021 | 03:28 PM
B52bombardier1's Avatar
Hello,
Try this:
https://www.psiconversion.com/produc.../KIT-1002.html
Rick
