LT1 to a Ls3 swap
I know that I need a ls1 k member and a LS steering rack in order for the ls headers to fit.
I wanted to use adapter for lt1 k member, but let know what your options are on that.
And I'm probably just gonna buy a 4l80e so installation is not so difficult.
What about driveshaft? And gear ratio? I got the stock 2.72 gears. Will that work with the 4l80e?
Also I want to know can I use a 411 ls1 pcm to run the ls3 wiring harness ? Or do I have to found the actual 2010 pcm?
And also I'm still confused on if I can use ls1 wiring harness or will it be best to get a ls3 wiring harness?
I've read that the ls3 is a DBW (Drive by wire) and i would have to swap throttle body with a drive by cable throttle body.
What else all I need? Any advice will help.
This is 1995 trans am btw
An LS3 will have a 58x reluctor, so you would need a signal converter to use an 0411.
In today's age, I'd go Holley EFI and not mess with the factory ECU.
Additionally, I'd start looking for a different rear and associated drive shaft, the factory 10 bolt leaves a lot to be desired.
Is this what your talking about? 👆👆👆
I was thinking about running a 3.42 gears, and I heard that the steel driveshaft is usable, and would be good for drag racing. Correct me if I'm wrong.
I'll follow up with, regardless of your driveshaft and gear selection, I'd ditch the factory 10 bolt if you plan to hit the tires with any intentions of drag racing.
I'll probably do a 3.42 swap on the rear.
Also will I be able to swap a drive by cable throttle body with out issue?
You can run either DBC or DBW as you choose.
Sorry for the newb questions, I wanna make sure that I do this correctly.
