1992 Buick Roadmaster Questions
I am a big guy and do not fit In most cars. I found a 1992 Buick Roadmaster i like, 4100 pounds I would like to LS swap I would like to know what the ecu in the car controls so if i remove it what it will efffect. It will be a slow moving project because i will be doing it around work. All so is the rear end any good in the roadmaster for performance.
You might want to use the SEARCH button to research your questions. Maybe find another thread that’s the same and PM the OP to pick their brain
