E38 DBC for Boat
Old Aug 27, 2021 | 04:25 PM
xcomunic8d's Avatar
Default E38 DBC for Boat
So it’s an old question in a new way.
anyone know if you can convert a gen 4 harness with the E38 pcm to run dbc? I have a gen 4 LS (LMG?). It’s a 58x/4x 5.3L. It looks like the pins are there and if you swapped the wires into the connectors and programmed the pcm it might work, maybe? I’m referring to the J2 connector pins 3, 5, 6. I’ve finished rebuild and found this problem. I was originally going to run Holley terminator x but you can’t get one for nothing right now.
My only other option I see is to get a ligenfelter trg-002 (converts 58x/4x to work on 24x/1x harnesses and pcms), get a LS1 harness (blue/red connectors) make it a stand alone and get a compatible pcm. Part numbers or suggestions appreciated.
the engine has a coupler bolted to flywheel and a splined shaft slides in to drive the bravo 3 outdrive. No trans etc. there is a mechanical shifter cable to change fwd to rev in the outdrive for those who are curious (no electronics involved).
I put a call and email into Brendan at lt1swap but was hoping you guys might know or point me in right direction. This is kind of different from what I searched here.
Old Aug 27, 2021 | 05:18 PM
No Gen IV engines have DBC capability, as the TB has idle compensation integrated into the throttle blade operation rather than IAC valve.
Old Aug 27, 2021 | 05:40 PM
xcomunic8d's Avatar
Ok so utilizing the pins is not possible is your answer? It appears on pin diagram that functionality is there and has to be somehow for dbw to work. The question is can the pcm handle seeing it differently? I’ll say I’m 99% sure this won’t work.
but what about switching to a dbc TB? Then converting with ligenfelter trg-002, LS1 harness and a pcm…
Old Aug 27, 2021 | 08:07 PM
Wouldn't there be away to use a DBW pedal module adapted to a marine throttle control? No cables...
Old Aug 27, 2021 | 09:20 PM
xcomunic8d's Avatar
I don’t see how… the throttle controllers are vastly different. Everything would be me inventing something that’s just not reliable. I’d rather turn myself inside out on wiring vs a control thats not proven or designed for salt water environment. I’ve spoke to various vendors of potentiometers none of them recommend this. Dbc is the the old reliable. I’m going 15-20 miles offshore in serious conditions. There is no uscg on my island, if something happens you’ll be out there overnight minimum. No risks can be taken when you got families and kids on board.
Old Aug 27, 2021 | 09:51 PM
Michael Yount's Avatar
In 24 years of DBW operation in cars - never a failure. In 26 years of cable operated carbs/throttle bodies - 2 broken cables. ‘Course - I reckon in that case you could have a family member operate the throttle…
If you must have a cable, I think you’ll need a DBC throttle body, computer and harness and the 58x to 24x adapter.
Old Aug 27, 2021 | 09:53 PM
gjestico's Avatar
If you want ultimate reliability, I wouldnt be putting that 58-24 conversion box in there.
Get a 24x crank wheel or an aftermarket EFI. Marine engines are so simple I'd megasquirt the thing. Where do you plan to put the Ox sensor, which the Holley depends on ?
Also, There are electric based marine throttle levers out there, All the bigger boats use them. If you really really want to get to basics you could run a carb and MSD ignition box.
Old Aug 27, 2021 | 10:07 PM
xcomunic8d's Avatar
in my boat swap thread you’ll see the risers are designed to accept O2 sensors. I spent big bucks and major research on that one. I was gonna do the terminator x but you can’t get one right now. Since June. And 371 preordered ahead of me no delivery date in sight. End of October on website.
yeah I suppose I could do msd box and carb. but I really wanted to keep my tbss… I’m aware I could spend thousands and get solutions but if I wanted to drop that coin I wouldn’t be doing this. There are foot pedals out there but that isn’t ideal for trolling. I have a twin lever controller I really like.
Old Aug 27, 2021 | 10:09 PM
xcomunic8d's Avatar
exactly. It’s how can you make it get home if it breaks. Also assume everything is going to get wet… like drenched. I’m not on a nice little lake. 5-8’ is normal ocean conditions here, been out in 13’ in a 17’ boat. That was bumpy.
btw I do have the dbc tb, I’m scratching my head now to make a work with b at the moment.
