5.3 to ls2 intake manifold
Old Sep 3, 2021 | 01:15 PM
skrelo's Avatar
Default 5.3 to ls2 intake manifold
is 2006 GTO 6.0 intake manifold interchangeable with a 5.3? the 5.3 has 799 heads.
Old Sep 3, 2021 | 01:34 PM
Teddy-2000RS's Avatar
Yes they are both cathedral port intakes. The fuel rails, evap stuff, etc. will all be different however.
Old Sep 3, 2021 | 08:38 PM
skrelo's Avatar
where can i find the parts i need? i found the fuels rails on glenns auto but i can’t find the evap
Old Sep 3, 2021 | 08:43 PM
Rich-L79's Avatar
FYI: the LS2 intake manifold is one of the worst LS manifolds ever made.
Old Sep 3, 2021 | 09:07 PM
skrelo's Avatar
i’ve been hearing that as well, everyones been telling me that a ls6 would be better
Old Sep 4, 2021 | 04:28 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If your conversion has hood clearance, any of the truck manifolds are better than the ls2, and in some ways better than the ls6. If you are worried about how ugly they are, there are several threads showing how people have shaved and painted them into nice looking pieces.
Old Sep 4, 2021 | 07:52 AM
fieroguru's Avatar
I went the LS2 intake for my 5.3L build (LS4 - which truly has a terrible intake) and have been really happy with it.
Yes the LS2 is down about 15 hp vs. the LS6 on a 6.0L engine at the 480 hp level, but the difference on a 5.3L build will be less, unless you plan to spin it past 7K rpm.
The LS2 is a very clean looking intake and I kept the LS4 fuel rails and used the LS2 Injectors and Throttle body.
Old Sep 4, 2021 | 09:09 AM
The 5.3, being .7 liter smaller than the LS2, likely does not tax the manifold's full potential, thereby making the LS2 intake not as bad a choice for smaller engines. Does this hold water??
Old Sep 13, 2021 | 11:45 AM
ryeguy2006a's Avatar
You can't ask a logical question like that and expect the internet to give you a good answer haha
That said, I'd say that is a reasonable conclusion that the LS2 intake would work well on a smaller cube motor. Another good choice OP is the Dorman LS2 intake. They are ridiculously priced new ($921) but I've seen a few used ones go for about the same as an LS6 intake.
