fuel pressure question
Old Sep 8, 2021 | 12:40 PM
not2oldchevy's Avatar
Default fuel pressure question
2003 5.3 engine Will it hurt to run with the fpr vacuum line plugged? that is the only way I can get 58lbs pressure.
Old Sep 9, 2021 | 09:09 AM
Jimbo1367's Avatar
Try it :::::::shrug:::::::
Old Sep 9, 2021 | 09:43 AM
Where is the pressure otherwise?
Old Sep 9, 2021 | 10:02 AM
50lbs drops in the 40s when you give it gas. Tried 3 different fpr all the same
Old Sep 9, 2021 | 10:55 AM
ls1nova71's Avatar
Is it a flex fuel engine?
Old Sep 9, 2021 | 05:49 PM
NO seems to run better with vacuum hose pluged
Old Sep 9, 2021 | 05:52 PM
CattleAc's Avatar
Bad pump.
Old Sep 10, 2021 | 06:11 AM
jimmyg's Avatar
Where is regulator? Should be after the rails on return side . Injectors need the full volume of fuel .reg is just a valve that pinches it off to create pressure
