PWM recommendations
Old Sep 17, 2021 | 10:25 AM
tmcmillan5's Avatar
Default I just got the car on the road last week. Ground up restomod
Old Sep 17, 2021 | 12:47 PM
WHOA! Clean ride! Nice color!
Old Sep 18, 2021 | 06:42 AM
Michael Yount's Avatar
What car did the front fender vents come from?
Old Sep 18, 2021 | 08:09 AM
Jimbo1367's Avatar
Damn that’s a nice car
Bandit,
thanks for chiming in. That info is very informative and something car cars should consider when buying parts It pays to have engineers around. Good stuff
Old Sep 18, 2021 | 08:25 AM
bochnak's Avatar
Originally Posted by CattleAc
I have the same Windstar fan setup in the LS powered 72 A-body wagon in my avatar.
I run this dual relay setup in mine...
These are 70 amp relays...I'd have to look, but I think I run 30 amp fuses for each fan...never had a problem running both or just one. (I trigger mine with the factory ECM)
I know this is probably a mute point if your going PWM.
Can you share a link to that relay fuse block?
Old Sep 18, 2021 | 08:45 AM
tmcmillan5's Avatar
70/71 Vett as I remember. I had to cut them way down as you can see. One row off the bottom and the rearward splay. I in-layed them so the fit was perfect. Took a ridiculous amount of time but so didn't the entire resto.
Old Sep 18, 2021 | 10:04 AM
I THOUGHT Vette but couldn't place the year! 'Cuz you went CUSTOM on us! Oh yeah...
Nice job!
Old Sep 18, 2021 | 01:01 PM
CattleAc's Avatar
Sure. I better PM you. I don't think they're a sponsor on here...
Old Sep 18, 2021 | 01:06 PM
Speedway Motors sells them and a single relay version. Made by Leash Electronics.
Old Sep 20, 2021 | 06:09 PM
-TheBandit-'s Avatar
Any time. You can find a lot of fuse performance curves here: https://www.eaton.com/us/en-us/produ...nt-curves.html The trick is knowing the magnitude and duration of the inrush current for a given fan & electrical circuit.
To illustrate the difference in fuse form factor, l'll propose a hypothetical. Let's assume the fan draws 20amps when running continuously. The inrush current to start a DC motor can be 2-3times the running current (rule of thumb), so let's assume 2.5x or 50amps. If you have a 30amp ATM fuse, based on the performance profile linked, it will last less than 3sec before the fuse blows at 50amp. If you use a 30amp MAXI fuse, you'll get 40sec before the fuse blows. If that 50amp inrush current only lasts say 5miliseconds, that would be a difference of 600 starts for the ATM vs 8,000 starts for the MAXI. Both are 30amp rated, but there is a significant difference in how many times they can start the fan before they blow.
Electrical engineers have several techniques available to limit inrush current so these things don't happen. I'm a mechanical guy so my knowledge is limited.
Old Sep 20, 2021 | 08:35 PM
And part of the reason for the PWM/variable current controllers is they "soft start/stop" the fans significantly reducing the inrush - and a similar thing happens when they turn off - you get a "spring" like bounce of voltage. I had mine on the stereo circuit and the starter (big mistake), and every time I'd start the car, the voltage spike/drop was low enough to clear my presets. Duh.
Old Sep 21, 2021 | 09:25 AM
  #32
bochnak's Avatar
I'm also building a 70' chevelle with windstar fans. Originally was going to do 2x 30-40A relays, which can set you back $60-90 once all said and done, not to mention it burns up an ECU output.
Thanks to the suggestions above, I looked into the Northern Rad PWM (Spoke to Carl from Vaporworx yesterday, who was part of bringing this to market, and also running his Vaporworx PWM for my fuel module) and am sold on the concept due to these benefits:
  • Costs about $175, not much more than relays.
  • Standalone, does not require ECU ouput. Will be using termx with only 4 avail.
  • Soft start
  • Super simple wiring
  • Small in size (I was also looking at DCC and autocoolguy)
Here is more info:
https://www.pro-touring.com/threads/...-PSM?p=1330793
https://www.northernradiator.com/Pro...riteria=Z18350
Instructions
https://www.northernradiator.com/use...structions.pdf
You can buy them on ebay right now:
https://www.ebay.com/itm/13343689912...EAAOSwLN5e48q-
Old Sep 21, 2021 | 09:33 AM
  #33
  • Soft start
Here is more info:
Instructions
You DO know that Carl worked with Brian Baskin of DCC in designing the Northern unit, right? You're in good hands.....
Old Sep 21, 2021 | 09:49 AM
  #34
bochnak's Avatar
Yes. So that is why I called him yesterday and asked a bunch of Q's. Pretty excited for the fan PWM as it will simplify things.
Old Sep 21, 2021 | 09:59 AM
  #35
And if you mess around with things a bit, with a PWM controller you can even have a "fan tach".....
Old Sep 29, 2021 | 10:05 PM
  #36
ebradley's Avatar
+1 agreed
