How do you run cruise with an E38
Old Sep 26, 2021 | 10:05 PM
rubrhammer's Avatar
Default How do you run cruise with an E38
Looking to do a 6.2 swap and want to run cruise. I know it's not like the Gen3 setup. Haven't found anything yet. Help?
Old Sep 27, 2021 | 09:04 AM
Jimbo1367's Avatar
Is that a DBW? Dakota Digital had modules for that
Old Sep 28, 2021 | 10:33 AM
Chocolate Apocalypse's Avatar
The Dakota Digital STA-1000 would probably do the trick.
Old Sep 28, 2021 | 11:24 AM
L92 OLDS's Avatar
Default Dakota digital
I’m in the same boat. I use an E38 to run my 6.2. The Dakota digital module do you need is actually the CRC-1000. I haven’t pulled the trigger yet at $400. 😮
Old Sep 28, 2021 | 05:26 PM
aknovaman's Avatar
it you are handy with wiring, you can snag a bcm from a truck, and have your tuner load the truck vin in your e38 ecu. Connect power, ground, CAN bus wires to the bcm. get the specific resistor values for the cruise switches and wire up a few push button (momentary swutches). I found the values and diagram in all data. you will also need the brake switch and brake light inputs to the bcm. Its much cheaper than the aftermarket systems.
the bcm is generally a one time program box so it's easier to program a matching ecu.
u wrench it has bcm for about $30. just remember to get the vin to marry the ecu to the year, make and model bcm and ecu file. it does not work for all years and chassis but it does work for some.
Another option is to spend $600 and get one of these.
https://oecontrols.com/product/tap-n-cruise/
Old Sep 28, 2021 | 07:02 PM
Michael Yount's Avatar
I have a 6.2L running on an 08 Corvette E38 ecu. Use the Dakota Digital cruise with my Rostra cruise control stalk on the steering column. Rostra actually engineers/manufactures Dakota Digital's DBW cruise unit. Works as well as the OEM cruise in our daily drivers.
