89 K2500 swap A/C help
I am going to be lazy and ask, has anyone swapped on of these trucks 88-94 GMT400s and kept the A/C? If so could you possibly direct me on how I need to wire this up?
I am using the stock harness that’s been thinned out, and my own fuse/relay panel.
Any help or guidance would be greatly appreciated!
Yes it does actually. My truck did have AC stock, and I had the complete donor truck so I removed and kept everything. I was over thinking this I’d say.
I should be able to leave my stock AC systems wiring as is, and pretty much replace the 89s compressor connector with the 02s connector?
After typing that I realized something, the air inlet pressure switch (closes 220 opens at 170 psi) is located on the original compressor. How will I have that limit switch using the 02s compressor? I plan to use the 89s original al accumulator and make the hoses work between everything else. I am also going to use the 89s condensers too.
Does the PCM just need to see that the AC is on for it to bump up idle speed or turn a fan on? Does only 1 wire go to it?
thanks for the help!
I don't see where the factory high pressure switch is. The switch on the compressor shows to turn on cooling fan. You could test and jumper switch connector to confirm. If you wanted, you could add a high pressure switch anywhere in the compressor discharge side before the orifice tube. The switch should open/turn off comp pwr when > 325psi.
