Brushless electric fan
thanks
I really like talking to these guys at PRI every year too. Very helpful, willing to show off their stuff and talk about it all day.
But it's not from a "newer car" and it's not brushless.
Its very thin, very lightweight, and extremely quiet. 25A full tilt, although again in testing, it was only 22A.
I'm actually considering getting a larger radiator just to be able to fit the 18" fan.
Be careful on the Thunderbird/Cougar fans. The OEM ones are much better than the aftermarket stuff.
Many people have bought the aftermarket ones and tested them to come up with less than 2500 CFM.
I know a fan from a 07 HHR is about perfect size but the darn thing is like 4.5" thick, looking for something to give me more room in the front of the 65 nova.
I always try to use an OE fan (and if it's from an older model, get an OE replacement motor for it). They are always high quality units. First, the fan that a vehicle manufacturer installs has to last the entire vehicle warranty period. In addition to that, if a Ford (or GM or Toyota or Honda) radiator fan fails, Ford (the vehicle manufacturer) not only has to replace the failed radiator fan, they also have to repair/replace the damaged engine that results from the overheating from the failed radiator fan. To the vehicle manufacturers, the warranty costs of cheap fans far exceed the price of a high quality, properly sized (usually oversized with a good margin of safety) radiator fan. Aftermarket stuff (especially "performance" aftermarket parts) have a shorter warranty, and if a Spal (or Mishimoto, Delta PAG, or whatever) fan fails, the most you're going to get from the fan maker's warranty is a new fan. There's a lot less incentive for quality in the aftermarket.
I've always felt that the aftermarket fans were inferior to the OEM fans. Part of it is due to the overwhelming positive stuff I've read concerning the old MKVIII fans, Ford Contour fans and 4th gen F body fans. Part of it is due to what I'd heard way back when concerning the crummy, aftermarket "Black Tragic" fans. It sounds like the SPAL fans are outstanding.
I always install the biggest radiator I can fit in my LS projects.
https://www.tbssowners.com/threads/c...ontrol.241568/
Andrew
