I don’t know if it’s a conversion…LS4 to RWD in a 1980 Corvette
That's fair, and not out of line with a C3 vette. But I wouldn't let a bad experience dictate your plans. Past failure doesn't mean future failure, just things you need to consider to avoid future failure. But its your call, of course. Most of the time, for a mild engine, it should be pretty simple to put in a tune and be fine for years. I fought my 'stock' ECU for 2 years, and then installed a Holley Terminator X in the first week they hit the market. Tuned it myself over a couple weeks, and haven't touched it since. Running the same setup in my LS swapped C4 vette.
That was a good thing because I was completely terrified of phucking something up by messing with it.
This time around, it’s a set of jets, or an adjustment to the idle mixture screw, maybe a different secondary spring, or a different pump squirter. Stuff so stupidly basic the only thing easier to do would be twisting the air cleaner wingnut to get the air cleaner off to work on the carb.
It works.
The dry run mock up test with the crank mounted, the starter mounted to the plate, and the bellhousing bolted to the block worked. In the end, using a starter that I already had, I have a grand total of 225.00 in parts, and a days labor to make it work.
Despite that, I’m sure that anybody that reads that is saying to himself “ Big deal, why not just use the right engine in the first place?”
And to which I’d reply, Had I known what I know now, I would’ve.
I made a mistake. I didn’t know that a freakin LS4 was a fwd only engine. After getting it back home, I just tore into the thing, and started removing “ LS4 specific stuff” like the goofy assed water pump menagerie on the front of the engine, and the backwards pointing intake manifold, like there was no tomorrow, all with no regard to giving one minutes thought to…..”Wait just a damn minute here”…..
This **** don’t look right.
The “all aluminum” thing seemed to be the only thing I could see. After tearing off all of the stuff that was bolted on, I ended my ability of returning a complete engine for a refund, I stuck myself with this engine. I had to make it work.
Fortunately for me. I was able to do that, W/O it costing too much.
Now that it’s done,…I could’ve bought an LM7 for 1850-2000.00. ( which would be almost double what the LS4 cost) Added about 100 pounds to the front of my car via the cast iron block, traded away the measly 18 hp advantage the LS4 has over it, and probably would’ve preferred the 9.5:1 cr over the 10:1 when it comes to putting gas in the thing. But all of that is too late….Lesson learned. The hard way.
The following users liked this post:
70ssHotChevy (03-26-2023)
I’ve done 20 or more swaps with stock harnesses and ecu’s never had an issue. Timing tables right on, fuel tables right on, start right up, never an issue. Converting to a carburetor seems to be more costly than keeping the efi.
This was the 4.6 I had in my last fox mustang before the fairmont with the 2jz. This is how the LS will look.
with a carburetor…..
Bravo! In my opinion, this is what Hot Rodding is about. Making things work together that shouldn't. I like reading the threads with the oddball swaps. I can't even remember the last time I opened and read a thread on an LS swapped Camaro. I hope your starter mount works correctly!!
Posting pics of your previous probably stopped more people from trying to talk you out of this.!! LOL
I like the visible intake manifold on the Ford 6......Why no intercooler?
