Terminator X Max and AC
Andrew
Thank you for taking the time to respond. I appologize for not being more specific. So I am working with a 1969 Chevy C10 Truck with the 2000 era 5.3 LS and 4L60E. I have the entire truck rebuilt and was running with the PSI Wiring harness, but i hate not knowing what is going on with the motor or being able to adjust things, so the Holley Terminator Max is the ticket i think. With that all said, i have the entire thing re-wired with the Holley kit and this is where i run into my questions or issues.
The AC is a Vintage Air kit and was working with the PSI wiring installed. The wire i was asking about is the black wire, which if i am not mistaken is a ground wire. On the PSI system there was a wire that went to this (again, if i am not mistaken, the PSI system would increase the idle a bit to compensate for the compressor turning on) and well after removing the PSI system and now have this wire to connect somewhere, typically i would just ground it out, but i was wondering if there is a wire on the Holley system for this. I know there is an AC shutoff and an IAC Kick, not sure if either of these are for that, and maybe i just ground the wire?
Hope this clears up my earlier mess, lol. Sorry about that.
Vintage Air can easily be integrated with the Holley EFI at different levels. I find that the IAC kick input is rarely necessary for a stable idle, but it can be helpful in some cases. The AC shutdown output requires a relay to be wired in conjunction with the Vintage Air wiring for the compressor relay.
Andrew
I sent in an email to Vintage Air asking to clarify the Black wire on the AC unit, making sure i am not mistaken in that it is the ground wire.
Again, thank you to all of you for your responses. I know that sometimes these questions seem dumb or just crazy and so i appreciate you all taking the time to help out.
have you traced out the black wire to find out where its going? looking at the wiring diagram i dont see a black wire in the vintage air schematic.
Andrew
That means alot! Thank you sir! I have read alot on here (all positive) about you and your knowledge about the system, so I will take you up on the offer. I will try to not make the questions as open ended as this one was, and provide better info with it. Again, thank you sir for taking the time to share your knowledge and help.
