Wiring Help 411 PCM
Finally... almost there. Long story short, my harness is ill put together. I bought it in 2014 and there is no recourse for support / repair from the source. I already had to relocate 7 pins on the PCM connector (4 injectors swapped, wires for TPS, MAF & ALT in the wrong place). but now it starts, no codes when last I checked.
Went to put in in gear for the first time the other day, with dreams of putting it on the trailer to the exhaust shop, and.... nothing.
Checked out the Connector @ the 4L80 and everything is where its supposed to be. Checked the corresponding pins in the PCM connector and everything is there except for pin 75 on the blue connector. Turns out this is part of circuit 1020, one of two key on hot / start hot circuits, this one specifically for powering the transmission solenoids on Pin E of the 4l80 connector.
So, this leads me to believe that the guy who did my harness must have spliced in it somewhere else? Maybe with the rest of the pinks that are only key on hot. I think the only thing to do is to pull the whole harness back through the firewall and see where the wire from Pin E ends up. I can harvest wires from the original harness if I need to make a jumper.
I'm having a hard time deciphering how to fix this when I find it. Is it a Pin 75 to Pin E straight line or do I need to tie it in somewhere along the way. Spent so much time trying to figure it out, I can't trust my own crossed eyes.
After rereading your post, I think I know what you are thinking now. Pin 75 doesn't feed power to the transmission, it's just powered up by the same fuse. It's a PCM power, so as long as it has an ignition powered source, it will be fine. The harness builder must have just forgotten it.
Then, because it's also on circuit 1020, Pin E on the trans connector needs to be powered the same way? (key on + start hot). Or am I misreading the diagrams from lt1swap.com?
Thanks so much for your help.
Never seperated the tq converter and the trans, so I don't think it's a pump issue. Still no codes, I have access to a tech 2. I'm stumped.
