Will straight water kill the Water pump??
Old May 26, 2022 | 08:53 AM
64postman's Avatar
Default Will straight water kill the Water pump??
Doing a 5.3 swap in a boat, lots of complications but I'm determined. If I run straight raw water from the lake to the zo6 water pump I'm using will it kill it?? I've heard that the dex cool lubricates the pump but then I've heard different so I thought to ask here. I have a closed circuit cooling system for it where it can use a heat exchanger but the space and hose routing is proving to be a nightmare and I want it on the water for tuning before the sun goes to bed lol.
Old May 26, 2022 | 09:15 AM
SLOW SEDAN's Avatar
Coolant isn't allowed on many tracks so lots of guys run straight water. It won't kill it, especially as a temporary solution. After a few years of straight water I get a little buildup but the stock pump nor the Davies Craig have failed.
Old May 26, 2022 | 04:16 PM
Kawboom's Avatar
As you are doing this on a boat, you are aware that you need one of those boat rubber impeller pumps, right?
Old May 30, 2022 | 12:21 PM
garys 68's Avatar
Wouldn't worry about the pump. Car and boat pumps have been interchangable for decades. BTW, where did you get your crank driven raw water pump?
