L99 6l80e and wiring the brake pedal, HELP
So I've wired the brake pedal up on my swap. For reference, Ive got a 2015 Camaro SS w/ 6l80e. Ive converted the L99 to LS3 spec. Everything is wired up and working correctly, EXCEPT the brake pedal. I seem to have run into a weird situation and I'm kind of lost
Here is another thread talking about the same issue https://forum.hptuners.com/showthrea...-signal-to-e38
I'm going against X9 on the ECM harness. Im basing that off of https://lt1swap.com/2010camaro_ecm_pinouts.htm
I've got a 5 post relay that Im using a on/off switch on the brake pedal to power.
Here is the behavior of the relay:
- 0V when brakes not applied (attached to ground)
- 12V when brakes are applied
Using HPTuners, I can see the scanner show me that when the engine is off, the brake pedal reads correctly as on/off. When I turn the engine on, HPT stops showing any change. It just stays off even if I push the brake in. I've used my multimeter and the voltages and behavior do not change when the engine is running. I am throwing DTC P057C per the scanner. Ive tried clearing it, it keeps coming back. I actually dont know why its throwing that? It seems to throw it whether Ive got my custom 5 post relay or the OEM brake switch?
Things I've tried:
1. I bought the actual OEM brake pedal switch for a 2015 camaro. I wired up the signal to X9, Gnd to GND and 12v to 12v. It has the exact same behavior - works when engine is off, doesnt when on
2. I saw someone suggest wiring to the TCM connector too. I'm actually not sure how the camaro OS works, but I figured what the heck, why not. I wired to pin 6 on the 6l80e. This seems to make no difference, it works when engine off, doesnt work when engine on.
3. I tried putting a 1k resister inline on the ground signal for X9. That doesnt seem to have done anything
Help please?
Things I've tried:
Help please?
The brake pedal for 2015 Camaro is a dual sensor. 1 half goes to the ECM and the other to the BCM. X1 at the ECM has terminal 54 is the 5v, 26 is the sensor signal and 42 is ground in the ecm..
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/1087x555/brakeswitch1_634dcfce6dd2ef06cdd72aef9b246de7bbb33483.png)
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/1103x663/brakeswitch2_3be142a8487aa435495ab72c00efb885639c3c82.png)
