Need help with nss wires
Old Jul 12, 2022 | 11:26 AM
Gabe45u38958's Avatar
Question Need help with nss wires
I’m installing a DIY fuse block off Amazon. I have some wires from the nss called the transmission range switch signals. What do I do with them?Do I add another fuse for them? I need help
another question I have is I have a thick purple wire called the s wire what do I do with at the fuse block?
Old Jul 12, 2022 | 03:32 PM
dlwilson's Avatar
The transmission range switch signal wires should go directly from one of the switches on the side of the transmission to pins on the PCM.
This thread is helpful:
https://ls1tech.com/forums/conversio...-pin-outs.html
