2003 LQ4 DBC won’t start but will run
Ls swap won’t start by itself, but with like 10 seconds of starter fluid it runs like a champ. Once engine is warm it will start almost faster then I can turn the key, but the second it starts to cool back down it struggles or just won’t even start. I read that it could be injector related. Unsure what to check first as I unfortunately can only work on the car on saturdays as it is at my dads shop and I can’t interfere with their work.
Edit: I believe the fuel pump is fine as I hear it running the entire time while trying to crank and for a few seconds after. Any advice would be greatly appreciated.
Another edit: the voltage drops a lot when starting so idk if I just need a bigger battery?
thanks, I think it was a tune issue with the cold start fuel enrichment. And I think the computer fixed itself as it works just fine now for some reason.
