Corvette regulator distance from gas tank
All - I am using a Tanks Inc tank with a Corvette regulator. Is there a maximum distance from the in-tank pump to the regulator? I just put the tank in and ran the lines. The best place to put the regulator was on the boxed frame rail just before the transmission crossmember. Is that OK? Or too far?
Thanks,
Jim
Thanks,
Jim
I'm not sure that is critical. Just be sure the lines aren't crimped or bent too sharply. Free flow is what's important
The following users liked this post:
Old Buzzard (10-03-2022)
Yeah, I’ve mounted the corvette reg on the firewall of two different truck builds and it works great. Both of those with a 255 pump. I tried a 450 pump on another build and it was a no-go. Overpowered the corvette reg and fuel pressure was way up there.
