Cam position sensor
Old Oct 4, 2022 | 03:44 PM
MLM7447's Avatar
Default Cam position sensor
I have an LS4 that I’ve converted to RWD. Using the front cover but a Gen4 truck water pump. Everything is installed, except one thing. An LS4 cam position sensor stands straight up, which interferes with the back of the pump. I need a sensor oriented in a 90 degree style. While this would seem like it isn’t that big a deal, the sensors are all over the place with regard to size, mount depth, and mount style. I know that I’m asking for a needle in a haystack answer, but is there a guide that shows these things so I can see if I can make something work?
Old Oct 4, 2022 | 04:26 PM
Go with a Gen IV truck front cover if possible,and that sensor should fit.
Old Oct 6, 2022 | 09:35 PM
Project GatTagO's Avatar
https://www.rockauto.com/en/moreinfo...t=7192&jsn=505
