TPS voltage issues
Old Jan 25, 2023 | 11:13 AM
LS240_sx's Avatar
Default TPS voltage issues
I have a LS1 from a 2000 Pontiac trans am swapped into my Nissan and I am having an issue with the TPS voltage range.
Completely closed idle voltage ~.503
WOT (fully opened by hand) 4.343
input voltage 5.03 volts
I have a drive by cable 95mm Holley efi throttle body and it will not physically open any more. I have read that my voltage for WOT should be somewhere around 4.65, how do I get my WOT voltage up another .3 volts? Is this something that can be done with tuning?
Old Jan 25, 2023 | 12:55 PM
Why are you repeat-posting this issue? You're getting good responses in the original post......
Old Jan 25, 2023 | 01:00 PM
LS240_sx's Avatar
I thought it may be better in the other section because I’m not sure this has anything to do with pcm diagnostics or tuning. I couldn’t figure out how to delete it
Old Jan 25, 2023 | 02:38 PM
Look at the little buttons at the lower right corner of any of your posts. Hit Edit and go from there.
Old Jan 25, 2023 | 03:39 PM
Project GatTagO's Avatar
Do you have OEM EFI or a Holley ECU?
Andrew
