Ls1 or ls2 intake on LQ4?
From what I’ve gathered with either I need to address the water pump and an idler location.
Will the ls2 create more issues for me vs the ls1? Have read the ls2 flows better but don’t want to create and unneeded headache.
In regards to the FEA maybe change over to 2002 body FEA? Then you can use all stock parts.
The "Dorman" aftermarket replacement LS2 intake is good, its the OEM LS2 intake that is not.
Note that LS2 intakes take a 4 bolt throttle body, LS1 and LS6 will take the 3 bolt. Its easily handled by an adapter.
In general, its like:
Worst = LS4, down big numbers. Then LS2, but I don't have numbers on it. Next is LS1. Truck intake makes about 10-15 hp more than LS1. LS6 makes another 5hp. TBSS makes another 5 hp on top of that, and then the FAST intakes make another 5-20hp on top of that.
Dorman replacement LS2s are mostly like an LS6 with the bigger TB opening, and perform about the same as a TBSS.
All of those are plastic intakes with long runner, and give a good meaty power curve, so most of these gain everywhere, not just at the top.
I personally could feel the improvement going from my Truck intake/TB to my TBSS intake/92mm TB on my heads/cam LQ4.
Aftermarket intakes are all over the place, many make good top end HP, but few will make the midrange power that you likely want in this application. The ones that do will be tall.
In a Jeep application, I'd grab an LS6, Dorman LS2 (which got stupid in price), or a FAST intake of any size.
What about sourcing a set of LS3 heads and using my intake that I already have. Would it be that beneficial in the lower rpm’s for the trouble? Or should I stick the ls6 route?
Andrew
Really depends on the cam and trans/gears or torque converter, and the goal.
Under 4000 rpm, LS3 heads/intake usually is losing torque over any of the factory cath heads.
If it was a crawler, I'd want 706 heads and a Dorman LS2 or OE LS6 intake
If it was a rock bouncer, then I'd go with the LS3/LS3
