Headers For A 5.3 Swapped 350z
Old Feb 25, 2023 | 05:07 PM
Superdupercandy's Avatar
Default Headers For A 5.3 Swapped 350z
so i’m in the middle of swapping in a 5.3 into my 2006 350z and need low clearance headers. i’ve been looking and see the 5.3 has the same block as a ls1. would i be able to use ls1 headers for my swap? would the ls1 headers fit in the 350z or would i need to bang some things around?
Old Feb 25, 2023 | 06:20 PM
ALL LS engines but the LS7 share all the same external dimensions and mounting points. Headers are more about which chassis they're for. If you have a pair of headers meant to fit an LS1 into a 350Z they will fit your 5.3.
Old Feb 26, 2023 | 12:42 PM
ok i guess more or so my actual question is, will they fit in the 350z chassis? because with the swap kit they have the headers are like $1000 and i’m not really tryna spend that much if i can spend a little less and get ls headers.
Old Feb 26, 2023 | 01:23 PM
aknovaman's Avatar
TBSS manifolds fit.
Old Feb 26, 2023 | 06:41 PM
Originally Posted by aknovaman
TBSS manifolds fit.
im not to familiar with those are they low profile?
Old Feb 26, 2023 | 06:48 PM
Check them on Rock Auto. They look like they would tuck in fairly close. Left side available from GM, right side from 4 different vendors.
They are the same as those used on 5.3 Trailblazers
