L8T in place of an L83
Old Mar 20, 2023 | 09:26 PM
69chevelleguy's Avatar
Default L8T in place of an L83
Hi all, my L83 has some miles on it now, recently discovered a bad lifter. I have been told it's easier to pull the motor to swap the cam and lifters and I was thinking instead of putting my motor back in with the miles. Why not look into putting an L8T in it. I have never seen one so I don't know what all would be involved in swapping one, I know they are cast Iron. What I don't know is, are the heads the same, can I use a short block L8T and swap it all over? What are the differences in putting one of the L8T's in place of a L83? Thank you in advance.
Old Mar 21, 2023 | 07:41 AM
ryeguy2006a's Avatar
No, the heads are different, but dimensionally the same. It would be a fairly straightforward swap, but you would need to have some fueling changes as well as some extensive tuning updates. DI is still pretty expensive and not a ton of guys are doing the tuning yet. But it's definitely possible.
