LSX gas tank pressure
Old Apr 11, 2023 | 06:08 AM
Chuck M's Avatar
Default LSX gas tank pressure
Hello All,
Thank you in advance for responses. -- Question I have is I'm running a fairly new lsx in 67 Chevelle and noticed a fuel leak on ground.. which was odd.
I went to back of tank gas filler and opened the cap and air pressure shot out... I currently have a Non- vented filler cap..
Would a vented cap be better to use OR is there another solution to resolve.
much thanks
Chuck
Old Apr 11, 2023 | 03:39 PM
LS1 TJ's Avatar
You have to use a vented gas cap.
Old Apr 11, 2023 | 04:21 PM
Chuck M's Avatar
Thank you Sir!
I don't know why I had a non vented -- go figure...
just fashioned my own from the non vented tiny drill in center for air -- Presto no more pressure ;{
Thank you again for the quick rely.
Old Apr 12, 2023 | 07:24 AM
33willys's Avatar
On my builds I do not use a vented cap but install a "rollover valve". It provides a tank vent but will shut of in a case where the car get upside down. Last thing you need is a case like this is a gas leak.
Old Apr 12, 2023 | 08:26 AM
ryeguy2006a's Avatar
A lot of guys will also use the rollover valve in conjunction with a charcoal filter so you won't get the fuel vapor smell in your garage.
Old Apr 16, 2023 | 06:07 PM
Project GatTagO's Avatar
Originally Posted by Chuck M
Hello All,
much thanks
Chuck
What you heard was air rushing INTO the tank, not out. As fuel is being used, if the tank is not vented, it will create vacuum inside the tank.
Andrew
Old Apr 20, 2023 | 01:17 PM
Chuck M's Avatar
Thank you for the Feedback... I'll pop on a regular vented cap that will allow air in -- Chuck
Old Apr 20, 2023 | 01:18 PM
Chuck M's Avatar
Thank you ! I'll look into those Roll over valves Appreciate the quick response! -- chuck
