6.2 swap fan control issues
Moving along but have a few issues I am struggling with. I have a standalone harness and ecu done buy a guy here in Ontario. The issue is i can not get the fans to run. The fuse box I was provided has relay and 12v fused outlet for the fan but the fan setup I have is from a 2016? Sierra and has a small brown and yellow wire as well. I have suspect this is to go to the ecu I do not have that input. The fan output I have is controlled by the ecu as the 12v output is not energized until up to temp.
I did read a number of forums talking about standalone systems but they were way over my head. I suspect I have everything I need here just don't know how to do it.
Any help would be awesome
You can also do it standalone with a very easy to install Four Seasons part number 35879 for maybe forty dollars USD. This device is completely adjustable for whatever fan temperature you desire while also immediately turning on a fan when the AC compressor kicks in - this to limit excessive compressor head pressures.
Rick
Rick[/QUOTE
I already have a standalone harness and ecu though. The system I have only sends fan power when up to temp. The issue I have though is that the fan itself has the little brown wire that requires ecu input that I don't have. Do I really need a seperate standalone to run the fans? I thi k it would be easier to switch to aftermarket fans that only have 2 wires. I'm stuck]
Rick[/QUOTE
If you were using Holley EFI, it would be easy peasy...
Andrew
