2006 silverado v6 to v8 swap, staying DBC?
How do I keep DBC doing this swap? 2006 rcsb v6 NV3500 non ac truck. Use a 99-03 engine or use a 04+ engine and swap the intake? I know it's possible because I had a 05 that the previous owner v8 swapped and kept it DBC but I don't know how he did it. Also that trucks igniton was on the key but he had the starter wired to a button. is that something I'll have to do?
The following users liked this post:
strutaeng (06-09-2023)
Some ECU on the later trucks had the driver for both DBC and DBW. There's a thread on performancetruck.net that shows you what to look for. I would probably just run DBW because I think it would make the swap easier.
I swapped an L59 from a 04 Suburban into my 1999 Silverado V6. Had to source a 2000 wiring harness and ECU from the wrecking yard separately because the harness/ECU that came from the donor engine wouldn't work.
Ignition switch on your old truck probably didn't have to do with DBC. Was it maybe a kill or security switch?
Edit: here it is: https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/how-too-dbw-dbc-swap-549983/
