Vol-PWM-Fan-LS1 controller
Today, I tested and finalized the Volvo PWM arduino controller code. Low speed might be a bit too fast but I can easily adjust it in the code. This would be ideal for a swap using the LS1 PCM to directly control a PWM fan. Next up is to mod the code for +12v (AC) input to make fan run at high speed. I have found Arduino microcontroller for less than $5 each. Another nice feature is the Volvo fan spins the fan at 'idle' speed for about 30 seconds on power-up and again at shut-down. This happens after the key is first turned on and after shut off.
Enjoy.
https://www.youtube.com/watch?v=SRxPoXvykC0
https://youtu.be/2gQPOVUTSyg
I am working on a demo vid showing a ls1 camaro pcm commanding high and low speed fans via my interface.
and hp tuners
