S10 LS1 Swap Rad Fan issues
Old Jun 27, 2023 | 04:24 PM
Timbwr's Avatar
Default S10 LS1 Swap Rad Fan issues
Hi everyone,
I have a ‘99 S10 with an LS1 out of a C5 Vette. Recently, my electric radiator fans stopped working. First I tried just redoing the crimp connection between the fan and the Current Performance wiring harness, and that made it work again for about a week.
A few days ago, it stopped again. I redid the connection again, this time with solder, and it still won’t work. I bench tested the fan with a battery and it worked fine.
Any ideas what could be causing the issue? Any help would be greatly appreciated.
Old Jun 27, 2023 | 07:33 PM
Check all other connections including grounds. I'm betting it's something simple.
How are the fans controlled? ECM? Or standalone? Check all that over too.
Old Jul 1, 2023 | 12:25 PM
rpturbo's Avatar
Did you look at the relay for it? My guess is the loose connection may have burnt up the relay.
Old Jul 1, 2023 | 01:44 PM
I second this. Good call RP....
