Who can make a custom accessory bracket?
Old Aug 11, 2023 | 02:49 PM
RovinC's Avatar
Default Who can make a custom accessory bracket?
I am (still) in need of someone who can make a bracket to mount the alt and ac on the pass top side of an LS
Ac mounted like the dirty dingo or many others, with the alt next to it (also made as a stand alone, but none together)
So my belt will go from the crank, up to an idler, around my PS pump, under the WP (truck/camero spacing) up over the SC pulley...
Then what I need.... from there the belt goes to an idler, under it and up to the Alt, around the alt and back down to another idler, under it and then to the AC. Around it, and to a tensioner (and another idler if needed?)
LSX innovations makes something like what I need, but they only make it for the LT not the LS
I need the Alt and ac mounted up high as Im using the stock ac location for an on board air compressor.
Ive called or emailed all the current bracket makers I can find and non are interested in the least, with most replying that they dont make such a product. Duh, thus my email ASKING IF they CAN make one.
So who can make this? Ive posted in other forums and never get replies or even suggestions.
Any other places here to cross post please let me know
Old Aug 11, 2023 | 03:20 PM
Kfxguy's Avatar
Without having the car in (whomever) possession or someone having the same thing you are wanting, I find it hard for someone to make that for you. If the bracket is a mere 1/8" off, the belt will squeak or squeal. Youll have to find a local fab (race car fabricator preferably) to build that for you.
Old Aug 11, 2023 | 03:46 PM
LS1 TJ's Avatar
I would check with ICT. It may not be a "stock" part for them but they might one off for you.
Old Aug 12, 2023 | 04:06 PM
RovinC's Avatar
Its just an LS with truck/camaro spacing, camaro water pump. Nothing special Ive offered to send the alt and the ac to them as well, but no takers.
Here in FL Ive gotten nowhere so thus asking on the forums
Old Aug 12, 2023 | 04:07 PM
RovinC's Avatar
Asked ICT and most others, no interest from anyone so far
