Clean air Dirty Air
1. The nipple on the left valve cover stays capped.
2. On the left side of the manifold close to the throttle body is a nipple for a purge valve connection. I don't need this on my swaps so I cut off the nipple and drill and tap it to seal it forever. In lieu of that you can just cap it.
3. On the right side of the intake is a u-shaped tube that goes from the intake to the PVC valve that is under the valley cover.
4. On the right side of the valve cover is a tube. I plump that tube with rubber hose from that tube into the air intake tube after the mass air flow sensor. That is the fresh air source for the engine.
