Scratch or crack? cylinder sleeve
Subscribe
View Poll Results: Run it or fix it.
Run it, it’ll be fine.
1
50.00%
Fix it.
1
50.00%
Voters: 2. You may not vote on this poll
Nov 16, 2023 | 11:07 PM
Have a gen 3 6.0 that was machined ( shop closed and owner retired) but I was ready to assemble the top end and realized on one of the cylinder sleeves had a line down the side and that if I rub my finger nail across it it’ll barely catch on the tip of the nail. Had another local Machine shop check it out they told me it would be fine. However as it’s my first build am second guessing it. The engine has a little torqstorm supercharger I bought for it so it’ll see a little boost which also is why I’m wanting to confirm. What do you guys think? Cracked or scratched and if so would there be a way to smooth it down a little?
engine has never been ran spent about two months on the engine stand while we moved.
Reply 0
Nov 18, 2023 | 09:14 AM
That's a scratch. I've never seen a crack perfectly straight like that. You'll be fine
Reply 3
Nov 18, 2023 | 09:41 AM
Looks like a scratch from a ring that wasn't filed properly of burrs.
Reply 4
Nov 18, 2023 | 04:47 PM
Any way to tell if they need to be replaced? Engine turns over smooth and doesn’t bind up at all.
Reply 0
Nov 18, 2023 | 04:48 PM
Ok thank you!
Reply 0
Nov 19, 2023 | 06:46 AM
I would fix it.. looks like ring burr.
Last thing you need is it to catch and snap the ring or piston
Reply 2
Nov 19, 2023 | 11:59 AM
A reason why you should take a little off the corners.
Reply 0
Nov 23, 2023 | 07:55 AM
I use a
Quote: A reason why you should take a little off the corners.
Very old points file for this.
Small, and easy to use.
Reply 0
Nov 23, 2023 | 07:59 AM
Yes sir, it was a tip I got from a Pro so thought I'd share even though I've read where not to do this but I found that it helps keep the corners of the rings from causing issues. Sure you may have a little more blowby but so what.
Reply 0
Subscribe
